Proxy server
Amber1986
Message 7 of 7
I am currently unable to connect my work laptop to my home WiFi (it works fine on other WiFi so seems to be a talktalk issue). I believe the security of my work network runs via a proxy server (as it says this is unavailable). Live chat were totally unhelpful and just said to change my username and password, and that it was for my work to sort out. Any suggestions?!
6 REPLIES 6
Message 1 of 7
I've ordered the router, should be with you within a couple of days but please allow up to 5 working days for delivery
Message 2 of 7
Hi Chrid
That would be great, thank you
Message 3 of 7
Hi Amber1986,
If you have a DSL-3782 I can arrange to send a different make and model, would you like me to arrange this?
Message 4 of 7
I will ask one of TalkTalk's OCEs to pick your thread up and they will sort it for you.
Message 5 of 7
Hi Kaith
Your assumptions are correct, thank you
Message 6 of 7
I assume that it is actually a VPN server at your work & you connect to it via a VPN client. If you have the TalkTalk DSL-3782 router, this would currently account for it, as the firmware blocks VPN access. It is waiting on new firmware to sort this. Please confirm if all of my assumptions are correct & then I'll get TalkTalk to send you an HG633 router to replace the 3782, as that does work with VPNs.
