Search instead for
TalkTalk Speed Checker - "Problem with your exchange"
xnoruk1
I've been trying to use TalkTalk's Broadband Speed Checker ( myaccount.talktalk.co.uk/speed-checker/) and it keeps saying "There is a problem with your exchange".
It asks "Do you want to continue anyway?" but clicking "Yes, continue" nothing happens.
(See attached screenshot).
TalkTalk service status shows no problems with my exchange.
Any help would be appreciated!
Thanks, Martin.
TalkTalk Team
Hi xnoruk1,
Which browser are you using? Do you have another that you can test with?
xnoruk1
Hi Chris, -- it does this regardless of browser. Martin.
Nathann
Retired
Hi xnoruk1,
Does the speedtest work if you use the following link (making sure you have logged out of my account first):
Nathan
xnoruk1
Hi Nathan,
After entering my phone number / postcode "manually" I get exactly the same error.
This is happening with my other phone number (see xnoruk2 forum account) -- they're both on the same exchange.
Thanks, Martin.
xnoruk1
Hi -- is there any update on this? Thanks, Martin.
TalkTalk Team
Hi xnoruk1,
I have raised this issue and I will let you know as soon as I receive an update back.
