Search instead for
Get Searching
Search now
Get stuck in
Try now
Join the party!
Register now
TalkTalk Webmail
SoftPops
Anyone aware of problems with Webmail at the moment (14:04 - 15/10/10). When I try to login it is saying incorrect password (even though I know it is correct. Cheers, Mart.
barney
Yes:(
Can't get into mine either:(
silverg
Just tried mine, same as yours :drool:
SoftPops
I'm glad to hear that it not just me - at least it means I'm not being stupid. :D
Donny
Also not importing email from TT into Thunderbird since last night. Something wrong with email servers or with the programming.
Cheers
Donny.:)
Thewizz
Wizz Kid
Cant get in either now, was OK earlier today :confused:
Donny
Seems to be working again and importing to Thunderbird ok. Hope it lasts.
Cheers
Donny.:)
alphac
Mine isn't. Not had access for over week now.
barney
An error message is now being displayed:
Login to Webmail
Due to a technical problem, the email service is temporarily not available. Please bear with us as our engineers fix this problem. Thank you for your patience.
It appears this is already in hand
SoftPops
Not yet for Webmail but a nice message has been put on the login screen:
" Due to a technical problem, the email service is temporarily not available. Please bear with us as our engineers fix this problem. Thank you for your patience."
Cheers All.
SoftPops
Login to Webmail
Hi Barney - me thinks we both looked at this at the same time! :)
Donny
Problem back again. Password not recognised.Is there still an issue with email.
Edit: Seems like problem with old links. If logged into my account and using the email link there, it works all the time.
Cheers
Donny.:)
SoftPops
Although there is still a message being displayed on the login screen...
" Some of our users are experiencing delays in receiving their emails. Please bear with us as our engineers fix this problem. Thank you for your patience."
...I seem to be able to use webmail without any problems this morning. Hopefully will stay like this!
SoftPops
:(Webmail seems to be down again today. Giving me a "ERROR_CODE:420
Service temporarily unavailable. Please try again later."
message. Has been like this since about 10:00.
SoftPops
Seems to working again (from Firefox) this morning. Will try again on IE on Monday.
OCW_Andrew
Retired
Hi all,
Is the webmail service now working?
Andrew
SoftPops
Good Morning All (just). Webmail has been working normally for me since Saturday (via Firefox at home and IE at work).
OCW_Andrew
Retired
Hi SoftPops,
Thanks for confirming the service is working. If you get any more problems let me know.
Andrew
