Search instead for
TalkTalkMembers Speed Test Results
chrissdp
absolute beginner been trying to access results ? how do I do it .
been reading about clocks etc.?
barney
Hi chrissdp and welcome to the forumsSmiley Happy
You should be able to see the clock icon under your forum name to the far left of your post above - if you click on that it should direct you to a separate page showing your speedtest results.
Kind regards
Barney
K9
There is a little clock below your name beside small rep scales, this will give you access to results
chrissdp
found my clock now I wrote a post. (TT says have to be a forum member but doesn`t say have to write a post?)
Banned
You have to be logged into the forum to see your speedtest results.
HRAY
To get a clock (your speedtests visible to other members but they cant see your phone number but you have to enter it to record) you need to amend your forum profile
chrissdp
Kind regards
Barney
Thanks found the clock.
TalkTalk Team
Thanks for the update Smiley Happy
