The WAN DHCP client process has failed on Vlan 36
61 REPLIES 61
Hi All
I've recently moved to TalkTalk broadband and have had internet connection issues from my Go Live date.
I'm using the Wireless Router provided by TalkTalk and the maintenance log keeps showing this error: "The WAN DHCP client process has failed on Vlan 36".
Troubleshooting attempts:
-Router power cycle (no resolution)
-Router factory reset (no resolution)
-Bright Spark engineer did a line check and came back FAIL
-2 tech support agents did line check and came back PASS
What does "The WAN DHCP client process has failed on Vlan 36" mean and what is the cause of this error? TalkTalk tech support has repeatably failed to help and I cannot find any help thread on the TalkTalk forums or wider internet.
Cheers
Josh
VLAN 36 is not used by residential customer installations, are you therefore a TalkTalk Business customer?
Super Duper Contributor
vlan 101 for residential fibre customers, have you tried setting the vlan to that? or alternatively, factory reset the router back to standard so that it's back to where it should be / was originally?
Hi Keith
Thanks for the fast reply.
I'm a residential customer, not a business customer.
Cheers
Josh
Hi Stuart
The VLAN is set to 101. I also did a factory reset yesterday and haven't changed any of the settings since.
I have a new router from TalkTalk due to arrive soon. I really hope that fixes the problem because I've been strung a long for a few weeks now and they delayed me long enough so that I am outside of the cooling off period.
Cheers
Josh
ensure you log a call with the voice support team and ensure you get reference numbers so that you can quote them later. make sure you have the reference numbers and ask for the loyalty team, so you can tell them if you aren't happy they are aware you weren't happy during the cooling off period, and follow advice to comply with fault finding issues so that you can demonstrate later either it worked or it didn't
Good advice.
Thanks Stuart!
does your phone line work? does the ethernet out of the back of the router work - wireless isn't great, and the router can drop connection every 20 minutes or so, so don't know if it doesn't connect, or is just not working all the time...
what do the logssay and would you be inclined to post them so that others / the OCE's (talktalk online support) can see what they say about your connection
I don't have a landline phone so I can't test that capability.
I haven't tried connecting to the ethernet port on the router however when I log into the modem itself, it says that there is no connection to the internet. I'll try to test the ethernet port.
 Below is the two most recent log pages. A few pages before these have many instances of "The WAN DHCP client process has failed on Vlan 36". I tried manually setting the DNS to the Google DNS but that didn't help.
Date/Time
Severity
Module
Message
01.01.2013 00:03:03
Error
DHCPC
01.01.2013 00:03:15
Info
SYS
Modem login was successful
01.01.2013 00:05:47
Info
WIFI
Device <84:16:F9:0F:54:77> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_VIDEO_5G])
01.01.2013 00:06:05
Error
DHCPC
01.01.2013 00:09:07
Error
DHCPC
01.01.2013 00:12:09
Error
DHCPC
01.01.2013 00:15:11
Error
DHCPC
01.01.2013 00:15:37
Info
WIFI
Channel: (11/1) Channel Hopping initiated/Manually initiated
01.01.2013 00:17:46
Info
WIFI
A WiFi device <84:16:F9:0F:54:77> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_VIDEO_5G])
01.01.2013 00:18:04
Info
SYS
01.01.2013 00:18:13
Error
DHCPC
01.01.2013 00:19:09
Info
DHCPC
The WAN DHCP client IP address 88.104.23.48
01.01.2013 00:19:10
Info
UPNP
UPnP functionality has been deactivated (manually)
01.01.2013 00:19:10
Info
UPNP
UPnP functionality has been activated
01.01.2013 00:19:12
Info
SYS
TR-069 connectivity to (acs.talktalk.co.uk) has been initiated
01.01.2013 00:19:14
Info
SYS
TR-069 connectivity to (acs.talktalk.co.uk) has been closed
01.07.2018 22:37:20
Info
WIFI
Channel: (1/11) Channel Hopping initiated/Manually initiated
01.07.2018 22:41:28
Info
SYS
A device reset was performed (GUI/Button)
01.07.2018 22:41:35
Info
WIFI
01.01.2013 00:00:15
Info
SYS
The Modem underwent a warm reset
Date/Time
Severity
Module
Message
01.01.2013 00:00:15
Info
SYS
The Modem has successfully powered up
01.01.2013 00:00:15
Info
WIFI
Channel: (0/11) Channel Hopping initiated/Manually initiated
01.01.2013 00:00:15
Info
WIFI
Channel: (0/36) Channel Hopping initiated/Manually initiated
01.01.2013 00:00:19
Info
WIFI
WLAN has been activated (TALKTALKB3A787) (band : 2.4GHz).
01.01.2013 00:00:19
Info
WIFI
WLAN has been activated (TALKTALKB3A787) (band : 5GHz).
01.01.2013 00:00:19
Info
DHCPS
The LAN DHCP Server is active
01.01.2013 00:00:20
Info
DNS
DNS name resolution is now active
01.01.2013 00:00:25
Info
UPNP
01.01.2013 00:00:27
Info
WIFI
01.01.2013 00:00:53
Info
XDSL
VDSL connectivity is up port 1
01.01.2013 00:00:55
Info
DHCPC
The WAN DHCP client process has successfully been launched on Vlan 36
01.01.2013 00:03:04
Error
DHCPC
01.01.2013 00:04:53
Info
WIFI
01.01.2013 00:05:09
Info
SYS
01.01.2013 00:06:06
Error
DHCPC
plug a phone in - buy one from local supermarket and leave it plugged in. there seems to be a keepalive that requires a phone to be plugged in, so that the phone line understands that it's working and not broken.
can get one for a tenner from argos or other supermarket/ b&m. plug it in, dial own phone, speaking clock (123) and 17070 (local line number announcement)/bt test phone number and leave it in. check for a noise on the line when you ring your mobile - silent line test - listen for crackles/beeps etc on the line or talking from others (crosstalk). then ring the call centre and ask for a line test, so that they can see that the phone is on the end and then reset the line card / get it done overnight. hopefully the fibre should work in the morning, now knowing that the phone service is working, the card for the fibre also knows to work too.
good luck.
make sure the call is logged, so that you can ensure there is a timeline to a resolution, also if it needs to be escalated to bt openreach, you should get another call reference number as well. make sure you insist on asking what the call reference number is - so that you know that it has actually been logged (whilst on the phone), so that it doesn't get forgotten about...
the vlan 36 bit is unusual compared to standard router - ask an oce to look at it, I am sure they will ask you to do a pinhole reset on the router  - put a paperclip in the reset hole when the router is booting for about 30 seconds and it should reset, becoming blank again. hopefully the config should be back to it's original settings.
https://help2.talktalk.co.uk/how-do-i-restore-my-router-factory-settings
Hi kronos319,
Can you complete your Community Profile and we'll be happy to take a look at this for you
Morning Chris.
I've updated my community profile. Let me know if you need anything else.
Cheers
Josh
good luck.
Thanks for the advice. I'll give it a shot and post back the results.
Hi kronos319,
Looks as though the router is out for deliver today, has it arrived yet?
@OCE_Chris wrote:
Hi kronos319,
I'll be home soon so I'll check and let you know.
Cheers
Josh
OK, thanks 🙂
@OCE_Chris wrote:
Hi kronos319,
Hi Chris
The router could not be delivered by UKMail. I called UKMail and they advised that only TalkTalk (being the sender) could amend the delivery address. I checked their website and tracked the parcel and had no option to specify my desired amended delivery address.
Ideally, I want the parcel sent to a collection point or my work address.
Cheers
Josh
