Unable to login to Dlink router
Barry G1
Message 20 of 20
Dlink router 3782. My broadband package works perfectly well in all respects except I can no longer log on to the browser (192.168.1.1) . The screen comes up as normal. After typing in admin & then the password a message comes up telling me 'my connection to the site is not secure'. The web interface then fails to load (unauthorised Access). All originally worked on supply of router (Feb 2018) as I haved changed the SSID's & password. I can see on the community I am not alone with this problem. I have tried every suggestion to no avail. A firmware update might solve the problem but as I cannot access the router this is not an option. If anyone from TalkTalk reads this I am happy to receive a replacement router to see if that solves the problem & return this one to you. Apart from this a rock solid connection with no problems.The previous Huawei router was returned because of this problem.
19 REPLIES 19
Message 1 of 20
Glad the Huawei router is working better for you and our team were able to assist.
Message 2 of 20
The 633 has worked perfectly from installation. I am always able to login to the router interface (The only problem I encountered with the Dlink) which as an aside is far more user friendly than the Dlink.
Speeds Up & down are solid giving around 37.5 & 15 at the router.
Thanks for your help & I am in the process of returning the Dlink to you.
Barry
Message 3 of 20
Hi Barry
Please let us know if you do experience any issues with the HG633 router.
Message 4 of 20
Tks for your help. I'm new to this community type service so not sure what you can see.
TalkTalk has supplied a different router for test purposes (HG633). This is currently working fine & I am able to access the router interface (192.168.1.1) & login. Dlink router was similar initially but over time would not let me login. For the moment logging in regularly. Hopefully this will continue.
Barry
Message 5 of 20
Hi Barry,
Sure that's fine. Please let us know how the speeds compare 🙂
Message 6 of 20
Current speed of the HG633 Router measured on a ethernet connected PC ; 35 up & 14 down.
Very good as it has only just been connected.
Dlink Router measured the same way earlier: 38 up & 16 down.
If you are happy I would like to hold onto both routers for the moment & if the HG633 ultimately solves the problem return the Dlink to you
Barry
Message 7 of 20
Hi Barry,
I'm sorry to hear this and I'm not sure why this happened. You would need to factory reset the router. Please let us know how the connection compares 🙂
Message 8 of 20
Michelle / Debbie
Test Router HG633 now connected. The router interface (192.168.1.1) came up but it took 3 attempts to log into the router interface & I was very careful entering the Router Password on each occaision. Is this normal?
I had one more attempt before becoming 'locked out'.
Question: In future if I become 'locked out' what is the procedure to re-enable the Login.
Otherwise everything fine & will monitor over the coming days (weeks)
Barry
Message 9 of 20
Hi Barry,
Great, thanks for the update 🙂
Message 10 of 20
Router arrived this morning. Excellent service Tks.
Will keep you advised once connected & take it from there.
Barry
Message 11 of 20
Hi Barry
No problem, please let us know how you get on.
Message 12 of 20
Tks Debbie
Barry
Message 13 of 20
Hi Barry
The HG633 router is on its way, please allow 24-48hrs for this to arrive.
Message 14 of 20
Hi Debbie
Tks for quick reply
I would be pleased to receive a router for testing. Hopefully should solve the problem. I would appreciate being able to hold on to it for a reasonable time before returning one or the other to you.
Barry
Message 15 of 20
Hi Barry G1
I can send a replacement HG633 router for testing, would you like me to arrange this?
Message 16 of 20
All personal details now inserted
Tks
Message 17 of 20
I will ask one of TalkTalk's OCEs to pick your thread up and investigate it for you.
Message 18 of 20
Using latest version of Chrome & have also tried with Edge. Both displays are the same.
Message 19 of 20
What browser are you using? All HTTP sites in most browsers report the connection as not secure & this affects most routers. However, a lot of browsers are getting very fussy over this.
