VPN
lindsey101
Message 10 of 10
Hi, I recently became a talktalk customer (3 weeks from being connected) and everything was working fine until last week when I can no longer connect to my works VPN. I have contacted techincal support, they couldnt help, passed me to business support, they couldnt help so as I work from home 3 days a week and really need VPN (have checked with company IT and everything is working fine their end) I decided to cancel as I thought I was in my cooling off period... seems that started at order date not connect day so I am no longer in it....
So, can anyone please help me? I am using my mobile data to access VPN at the moment but that is going to run out soon.
9 REPLIES 9
Message 1 of 10
Hi lindsey101
Message 2 of 10
That would be great!
Thank you.
L
Message 3 of 10
Hi lindsey101
I can send a replacement WiFi Hub for testing, would you like me to arrange this?
Message 4 of 10
Hi, I was able to use it fine until 2 weeks ago. It works fine on other providers too.
thanks
l
Message 5 of 10
Hi lindsey101
Were you previously able to use the VPN client with the WiFi Hub?
Message 6 of 10
Hi, yep tried that.
L
Message 7 of 10
Hi lindsey101
The WiFi Hub should work ok with VPN clients. Have you tried factory resetting the router using the pin hole reset for ten seconds? (and retesting)
Message 8 of 10
Hi, I have updated my info. I have the new talk talk WiFi hub, sorry I cannot find what make or model it is on it.
Message 9 of 10
Hi lindsey101
Which router are you using? (make and model)
