Search instead for
http://192.168.1.1/
ethermax
I've tried to access the above using "admin" password but keep getting error messagesSmiley Sad
Help please
Ethermax
ethermax
192.168.1.1/
For some reason the the above did not appear in my first post
I tried accessing the above but keep getting error messages using "admin" ? Smiley Sad
Again, help please
Ethermax
T_PC_R
Originally Posted by ethermax
192.168.1.1/
Again, help please
Ethermax
What router are you using, and what error message/s are you receiving whilst acccessing the router.
Have you tried turning off and on the router, A reset.
What steps have you taken to try and resolve the issue/s prior to posting.
ethermax
Router is EchoLife HG520s which I've had for some time but seems to function ok
However I'm experiencing slow connectivity and am trying to compile info to submit for investigation so , yes I've been rebooting router as part of my trying to find faster speeds
Only steps taken to date is calls to Broadband support and didn't get anywhere
Cheers Ethermax
ethermax
error message is as follows... :-
"The user name or password you entered for this area on 192.168.1.1:80 was incorrect. Make sure you’re entering them correctly, and then try again."
Ethermax
T_PC_R
Cheers Ethermax
You can try a factory reset by pressing the recessed reset button for aprox 15-20 seconds then let it reboot then try accessing the router by using the default user name and password both admin as you already know (only mentioned for other readers of the thread)
Here is a copy of the HG520s user manual incase you or others need it for reference.
ethermax
I'm a bit wary about any settings that I might lose by returning to Factory default
Having said that I guess its a good place to start.... seem to recall that Customer/Broadband support set something a few years ago ... dammit here I go
Be in touch to report progress
T_PC_R
Good luck I hope it works for you
ethermax
Well yes .... & no
I've lost all my security settings but good news I can access the 192.168.1.1/ (without seemingly needing to use either 'admin'
So now I can access the data I've been seeking and now need to re-configure the name & security settings I'd created at day one)
I can't actually recall how to do that but will have a think
Ethermax
bestmanx3
T_PC_R
Well yes .... & no
Ethermax
To re-configure the name and security settings
See Chapter 5.2 Changing the Administrator Password of the
HG520s
The Web manager of the HG520s provides the password
protection function to prevent illegal users from changing the
configuration of the HG520s. The username and the password of the
HG520s are configured by default. To change the administrator
password, follow the steps:
(1) Log in to the Web configuration page of the HG520s. For the
procedure, refer to 2.2 (4)"2.3 Establishing Configuration
Environment."
(2) Select Tools > System Management in the navigation tree
to display the system management configuration page.
(3) Find the username in the configuration page of system
management. Click the corresponding editing icon to display
the password configuration page.
(4) Enter the new password in the password configuration page.
Click Submit.
ethermax
Managed to re configure my Router ok
Phew!
ethermax
Thanks TCPR - I just discovered your input - but much appreciated
ethermax
Thanks also to BESTMANX
T_PC_R
You are welcome
Let us know investigation goes
A few things you can try (you will mos prob know most if not all)
1. Change microfilter
2. Change Ethernet cable
3. Unplug everything including your phone and re-plug in 1 item at a time to see if any of your equiptment is interfering.
4. Plug you router into the test socket with the microfilter
hope this helps you and other readers
TalkTalk Team
Hi ethermax,
Glad to hear the you have managed to access your router Smiley Happy
The errored seconds count has been very high which is probably the cause of the poor performance - Our DLM system change your profile from 9db to 12db yesterday because of the high errored seconds count and since then your connection seems much better - have you noiticed any improvement?
ethermax
OCE_Chris
So far today the best download has been 1.1Mbps(15:15 hrs) the worst 0.19 Mbps (12:20 hrs)
So not v goodSmiley Mad
What can you do ? previous best at 2.89 Mbps even then was nowhere near ........
ethermax
OCE_Chris
Just got download increase to 1.56 !!!!
After fitting interstitial plate
Will try a connection into test socket when my son can bring his laptop
Be in touch
TalkTalk Team
OK, thanks for the update Smiley Happy
ethermax
Just got a reading of 2.38Mbps however according to TalkTalk's speedtest the reading at the router was 1.83 Mbps so think there is an error
Comments please
