lower ping
15 REPLIES 15
imconfused
hi i was wondering if there was any chance that i could have my ping lowered it currently ranges from 60-75ms and that far to high if you could help that would be great 😄
thanks in advance
barney
Hi imconfused:)
If you are currently in an inteleaved line profile the forum staff (OCE) can try changing it to a fastpath profile for you which tends to produce lower pings and improved latency.
As the OCE are only online during weekday working hours it will be a little while before you receive a response from them, so may I please ask you to keep your router switched on until the OCE have picked up this topic so that they can ensure it regains connection if they do change the profile?
Kind regards
Barney
Hi imconfused,
I have changed the profile from 12db interleaved to 12db fastpath, please can you monitor the connection to see how it compares.
Debbie 🙂
imconfused
hi debbie thaks for changing it for me but i think i preferred it the way it was is any chance i could have it changed back sorry for any inconvenience
MikeDT
What don't you like about the new profile? If it has turned out a bit slower in total throughput than the interleaved profile, that's quite standard. It is only the ping that improves, not the throughput. However, by moving to a profile with lower SNR margin, you may be able to recover any lost speed. If you want to try that, post your full router stats (see www.talktalkmembers.com/forums/showthread.php?t=43877) and the OCE will see what they can do.
Hi imconfused,
No problem, I have changed the profile back to 12db interleaved as requested.
imconfused
hi I was wondering if I could do what MIKEDT said if that's possible
1. What exchange are you connected to? HALFWAY
2. How many telephone extension sockets do you have?2
3a. Do you have an NTE5 master socket?yes
3b. If yes to question 3a, have you tried the test socket?no
3c. If yes to question 3b, how long for and did you notice an improvement in your connection?
3d. Do you have an iPlate or ADSL faceplate? adsl
4. Is your modem/router connected to your Master Socket?no
5. Are you experiencing any problems with your phone service?no
6. What modem are you using? (Make & Model)?DSL-2640R
7. Have you tested with an alternative modem? (Make & Model)no
8. Have you tested with a different microfilter?no
9. Are you using a telephone extension lead?yes
10. What is your modem SNR Margin down and up? 9.2 down/12.9up
11. What is your bandwidth (Connection or sync speed) down and up? 4944kbps down/708kbps up
12. What is your attenuation down and up?51.0 down/29.7 up
13. Are you experiencing the disconnections at any specific time?no
14. Are you currently using Wireless?yes
15. Do you have an Alarms and/or Sky boxes connected to the telephone line?no
Hi imconfused,
I have changed the profile to 9db, please can you monitor the connection to see how it compares and also to ensure that the connection remains stable.
If the connection does remain stable following the profile change then please let us know and we can try a faster profile 🙂
Can you also ensure that the modem is set to always on or disconnect if idle is set to 0 in the modem settings.
To change the d-link to always on
open browswer and type 192.168.1.1 in the address bar, then press enter
type "admin" for the username and password and press OK
click on advanced in the left hand side menu
click on OK to the advance user warning
Change the idle time out to number 0 (by default it is set to 30) Click on save setting at the bottom of the screen
K9
6 db is the next fastest (and fastest profile available tho' also the most ustable) might be worth your while having a read through www.kitz.co.uk/adsl/socket.htm to see if your internal wiring is up to scratch
Hi imconfused,
Just to confirm, how have you found the connection?
imconfused
the connection has been fine so far I have had no problems with it
Hi imconfused,
Thanks for the update 🙂 Just to confirm, would you like to try a faster profile?
imconfused
yes plz that would be great
Hi imconfused,
you are now on 24isnr6,
Downstream Rate 6424 kb/s
Upstream Rate 905 kb/s
Downstream SNR 6 dB
Time in Sync 0 Day(s) 0 Hour(s) 2 Min(s) 58 Sec(s)
Attenuation 52 dB
let us know how you get on.
imconfused
just thought i would let u know the connection has been fine so far 🙂
