talktalk mail opens in basic mode
12 REPLIES 12
paulma
Every time I sign in to my AOL/TalkTalk mail account, it says I'm using an unsupported browser and therefore opens the Basic Mail version.  However, I'm using the most up-to-date version of Internet Explorer (11).  Very frustrating! Tried compatiibility view settings to no avail.
Bigmick
not an expert by any means, but I had the same problem.talktalk didnt seem to want to be over helpful, but the bottom lene was that the talktalk mail page is not compatible with ie11. Change to Chrome or Firefox which will work with talktalk.end of problem.
hope this helps.
Mick.
paulma
When I submitted this post it showed the browser used was:-
(Mozilla/5.0 (Windows NT 6.1; WOW64; Trident/7.0; rv:11.0) like Gecko.)
These are also shown on the pop up when logging in. Not sure where it gets this information from. When I rolled back to IE.10 still got the same problem.
Cheers, Paul.
Hi Paul,
have you tried using FireFox?
I'm not sure our webmail yet support I.E. 10.
paulma
Hi Ady,
Didn't want to go to firefox if possible. Works fine once you open in standard mode and occasionally opens in standard mode, Are Talktalk doing anything about this?
Cheers.
Paul.
Hi Paul,
Thanks for the update, (yes we will be working on this)
flamenca
I always use Chrome and its the same getting Basic
Fred_Sheehan
paulma
Already tried compibility mode to no avail. Even tried a desktop shortcut to http://cpw.mail.aol.com/ but that still opens in basic mode. Guess we will have to wait for the issue to be fixed by TalkTalk.
Cheers.
Paulma
flamenca
Whole thing needing scrapped and replaced. After telling friends and family to use TalkTalk for my email I will need to tell them tomove again.
John
alucard51micks
so it`s now  November, has this problem been solved ?
Please can you start your own thread for support. Posting or 'hijacking' another thread makes it difficult to follow a conversation, and also makes it more difficult for others searching for a solution.
We do try to keep each issue, no matter how similar to it's own thread.
If you can start your own thread, that would be gratefully appreciated.
Many Thanks
paulma
Just rolled back to IE10 and appears to be OK now.
Cheers. Paulma
