0 subscription channels showing
Cbanks
Message 3 of 3
New to TalkTalk TV today, all set up, showing 0 subscription channels despite retuning twice. How can I fix this? Want to access BT sport and it’s not even there at the moment
Message 1 of 3
Hi Cbanks
If you can answer the questions from fr8ys we can look into this for you.
Message 2 of 3
How have you connected the box to the router? Direct or via powerlines?
Have you tried accessing and playing iPlayer for example to check the box can connect to the internet?
If iPlayer works, then work backwards from the box and retune after each step.
Remove wires and reinsert them if you have not already done this and check your powerline plugs, if used have lights on. You could reset them and the re pair them.
If that does not work, the try rebooting the router.
If still no joy post back and you are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
Thank you
