4 od (4 catch-up) no new programs
Katp90
Message 3 of 3
 Hi so I've recently noticed that on 4 OD (channel 4 on demand) the most recent program aren't available to watch. The are available on my phone and tablet so it must be a youview box issue (?) I gone for example I can see week 2 of the bake off but non of the more recent.  I've tried all the usual, unplug, restart, retune and only having the TV connected to the WiFi. Anyone have any ideas? Or having the same issues.....
Message 1 of 3
Hi Katp90
As fre55die advises, the issues appear to be at C4 directly, they are working to rectify all issues.
fre55die
Message 2 of 3
Hi @Katp90
Channel 4 seem to be having a lot of problems currently as they are also struggling with subtitles due to a damaged transmission centre.
There are a number of reports on here, it is Ch 4, not the box and they are working hard to rectify it ASAP.
