on 17-01-2022 12:44 PM
Good Afternoon ,
I was sent a new DN360T TV box to replace my old original DN370T and was told I could keep the old unit and was then asked via an email if I needed any other equipment, ie. remote and cable, to which I selected the yes button. There was no confirmation of this having been sent or received. Nothing arrived so I waited until after the Christmas period and when it still hadn't arrived I decided to call Talktalk. I explained the position to a very helpful lady at the call centre who told me that she could not just send a remote on it's own but would need to send another TV box which would have a remote with it and I could return the one I had received. She asked me if my box was able to record and I said yes my old original box was able to record. She said I would receive a new recordable box and remote. She also confirmed that as this was part of my package there would be no charge for this or any equipment I had received.
A day or so later a package containing a remote and a cable arrived. I think this must be the one I had requested via email.
Then a day or two after this I received another TV box. This was a DN372T recordable box but minus a remote !
I do not subscribe to Talktalk TV anymore and do not want to keep anything that I am likely to be charged for and only accepted the first box as I was told my old unit would not update going forward.
My other concern is that the return bag which was sent says for old equipment to be recycled and I am not sure if useable to return new units.
I wonder if someone could advise me the best thing to do ?
Thank you Tim
on 17-01-2022 02:29 PM
You're Welcome 🙂
on 17-01-2022 02:26 PM
Hi Karl,
Thats great.
Thanks again for your help
Rgds Tim
on 17-01-2022 02:18 PM
Correct. The Remotes also work with all box models.
on 17-01-2022 02:16 PM
Hi Karl
Thanks for your prompt reply.
Just to confirm:
I can keep the new DN372T recordable box together with the new remote which arrived separately.
I presume the new remote will work with DN372T, it has a blue Menu button and a grey More tv button ?
The new & unused DN360T can then be returned using the returns bag.
Regards Tim
on 17-01-2022 01:42 PM
You can choose which box to return in the returns bag. The serial number of the equipment is linked to your account and out logistics teams can process the return correctly.
