All my scheduled recordings are Failed
Olly12
Message 5 of 5
All scheduled recordings have started failing, with "Failed to record". This used to work. Device is Huawei DN372T. It has latest software. See photos attached. Please help.
4 REPLIES 4
Olly12
Message 1 of 5
Ok, thanks. That sounds like a retrograde step (eg when compared with Sky Q), so will stick with the one I have for now.
Thanks for your help.
Message 2 of 5
TalkTalk can arrange a replacement box if yours is faulty, but this would only be a non-recording type, they no longer supply ones that record.
Olly12
Message 3 of 5
Hi Ferguson. Thanks. Tried these and eventually worked. Factory reset keeping recordings did not work, so had to delete all my recordings which was disappointing. I presume disk was faulty/corrupted. This has happened 2 or 3 times before. Perhaps you can send me a new box, as the disk must be faulty.
Message 4 of 5
