Amazon Prime
jakeybox
Message 2 of 2
I have a Amazon Prime subscription but my recordable TV set box does not support it .  I have been sent a new box but it is the wrong one, It is the non recordable box.  Can I please have a new up-todate record able one in it place please.
Jackie
1 REPLY 1
Message 1 of 2
TalkTalk now only supply non recordable boxes.
As your box does not support Prime, TalkTalk send out the non recordable boxes that do support it, so you can have access.
You can also get Prime on some smart TVs and via Firestick or Roku stick, which are quite reasonably priced.
