Bbc perfect. But nothing else. Why?
Guestiee
Message 2 of 2
Hi my talktalk box shows most bbc channels fine at 100% signal quality. But itv is unwatchable. Why might this be?
When I unplug the aerial cable and put it straight to my TV instead, all channels work perfectly.
Its so frustrating and the wife is moaning like hell coz I wanted this talk talk box!
1 REPLY 1
Message 1 of 2
We're happy to look into this for you. So I can find your details, can you update your community profile to include your home phone number.
If you dont know your phone number, dont worry, you can add your account number.
To check your phone number, you can dial 17070 from your home phone.
To update your info, go to 'My Settings'. then 'Personal Information', add your details, then click 'Save Changes' at the bottom when done.
You can also follow this link : Update My Profile
Let me know when you have done this.
