Boost Channels not working after BB upgrade
petec1966
Message 1 of 19
Good Morning, yesterday I upgraded my BB to Faster 150 Fibre, all appeared well. After popping out in the evening I returned to my wife saying that Sky One wasn't working ... I double checked a few channels. It would appear none of my Boost channels (including BT Sport) are working ... the gist is "There is a problem with your broadband ..." and ends with IPC6023. I have checked all cables, restarted box & router. still no joy. The only thing different from previous is a little white box that was installed that sits between phone point and router.
Any help graciously received.
Thank you
Pete
Pete
18 REPLIES 18
Message 2 of 19
Hi Pete,
All settings look ok this end, I've checked that the TV system is pointing to the correct network ID and the TV boxes are showing as registered.  Multicast is also showing enabled across all systems.
First thing to try, turn off openreach modem and TT router for 30 minutes to clear the session then retest.
If still failing then next option is for a multicast engineer to verify IGMP joins seen and the virtual circuit ID on their (openreach) side matches the one on our side.
Message 3 of 19
I'll give that a try now ... quick 30 min tea break where I don't need BB; WFH don't help. Cheers
Pete
Message 4 of 19
No Problem 🙂
Let me know as soon as you've retested.
Message 5 of 19
I have just rebooted both the OR modem & Router. Same result I'm afraid, boost channels not working
Pete
Message 6 of 19
Multicast engineer booked to verify exchange settings are correct.
Message 7 of 19
Thanks @Karl-TalkTalk.
Out of curiosity, is there a known time/date?
Pete
Message 8 of 19
Usually a multicast engineer reports back within 24hrs.  I've also another model router on the way to you so this can be tested.  If the multicast engineer verifies all settings are correct and multicast traffic can be seen across our cable link, then we can confirm the fault exists with the other router and escalate to our NOC teams.
Message 9 of 19
Thanks for your help today
Pete
Message 10 of 19
No Problem 🙂
Message 11 of 19
Morning. I got the replacement router this morning. Have installed. Checked all the wiring. Turned off router, OR modem & TV box, left for 10 minutes, then turned all back on.
Still the boost channels are not working.
What next?
Thank you
Pete
Message 12 of 19
Hi Pete
The multicast booking is still open with openreach, they have not updated us as yet.  I've emailed our SMC to ask they chase this up with Openreach to see why this has not progressed.
Message 13 of 19
Good afternoon, Is there any update on this. Boost channels still not working. Thank you
Pete
Message 14 of 19
Openreach have escalated this internally and asked us to contact them for the next update on 20th.
Message 15 of 19
OK, Thank you.
Pete
Message 16 of 19
Good evening. I have just returned from a week away, rebooted the new router and the OR modem. Still no boost channels playing.
Any updates from OR?
Thank you
Pete
Message 17 of 19
Hi Pete,
The issue is with our NOC teams currently, they have found a discrepancy in the config, so possibly a provisioning issue.  For some reason the system has you on a horizontal config rather than multicast.  It's as though the system is saying that multicast is not available to you, although your account is fully set up as multicast, so from an account side all is correct.
NOC are still investigating.
Message 18 of 19
Cheers Karl.
I'm now dealing direct with them via Teams.
Pete
Message 19 of 19
OK, I'll drop you an email also.
