on 20-05-2018 09:40 PM
My talk talk tv box has stopped working properly. Every time a scheduled recording tries to record, it fails. Every time a manual recording is attempted, it fails. Every time a previous successful recording is attempted to be played, it displays a black screen when playing.
I have tried the soft reset and the hard reset using the maintenance method (switch off, hold +/- buttons and reset box with keep recordings and removing recordings).
Can you please advise what the next step is? The hard drive still has about 38% capacity free and the signal strength is fine.
Anne Beaton
on 29-05-2018 11:41 AM
Hi Anne
Glad to her the box has been received. I hope it's working correctly and solved the issue for you.
on 29-05-2018 11:21 AM
Replacement box has been received. Thank you for your assistance.
on 22-05-2018 11:18 PM
Hi @swampdodger
Could you please start your own thread for support as each problem is individual and needs investigating separately.
Could you please also ensure that your community profile includes your PHONE NUMBER as OCE's will need this to tie up your screen name to your account. (click on your avatar to view the information, Settings, Personal information, then scroll to the bottom of page and click save) Only you and the OCE's can see this information.
on 22-05-2018 10:54 PM
i have the exact same problem and resetting has'nt solved it, even before, when it was recording only two lights (the 1st & 3rd) were showing.
on 21-05-2018 08:08 AM
Hi Anne
I'll get the box replaced for you.
on 20-05-2018 10:49 PM
Sounds like your box is failing.
I've escalated to the ice to confirm for you and consider next steps.
