Brit Box
EdwaltonFletch
Message 2 of 2
I understand that BT / You View now faciltates the access to Brit Box.
If that is a correct statement is it likely that Talktalk may also add the brit box app anytime soon ?
Another Fine Mess I Got Myself In
1 REPLY 1
Message 1 of 2
TalkTalk are normally behind in implementing new apps, but I'm sure it will be available soon.
no-one can be specific on this though as it would breach confidentiality agreements.
