Can I connect TTTV box wirelessly?
1 REPLY 1
30 minutes later
i currently connect to internet via HomePlug with max speed of 300(mbs?).
My TV box seems slow (I have a speed a wireless speed of around 75 as I’m on fast fibre).
So I wondered if I have to connect by lan or if I can connect wirelessly.
Thanks,
Steve
OCE_Karl
Officially you can only connect the TV Box wired directly or via powerlines.
Unofficially there are ways to connect a box via wifi, by using a nano router or access point that will connect to the ethernet port of the box.
