Can't load MORE TV
Bev9158
Message 7 of 7
Hi, I have box DN3604. Everything is working normally except MORE TV. When I try to load the tv screen goes blank and the box goes off. Tried switching everything off but still does it. Any advice much appreciated.
6 REPLIES 6
Message 1 of 7
No Problem 🙂
Message 2 of 7
Thanks Karl it worked
Message 3 of 7
The DN360T box is the one that does not record 😉
Message 4 of 7
Make sure you watch anything of importance as I feel maintenance reset may delete recordings.
Message 5 of 7
Can you try a Youview Maintenance Reset
See if this helps.
Bev9158
Message 6 of 7
Should be DN360T
