Change TalkTalk tv youview for one which records
rpalmer83
Message 2 of 2
I joined talk talk fibre max with tv in November and received the standard youview box which doesn’t support recording. Is it possible to get this swapped for the model which does record and would there be any additional cost? Thank you
1 REPLY 1
Message 1 of 2
Your best bet is to contact customer services directly and tell them what you want. They may require you to subscribe to the TV Select Boost initially, but there is only a minimum commitment of one month at a time.
