Changing channels by itself
RyanL
Message 11 of 11
None stop flicking through channels. Checked all buttons on front there okay. Changed batteries in remote and even when take batteries out it's still doing it. I've even factory reset it twice but still doing the same. Anyone help?
10 REPLIES 10
Message 1 of 11
No Problem 🙂
RyanL
Message 2 of 11
Thanks for your help much appreciated
Message 3 of 11
A TV box is now on the way to you.
RyanL
Message 4 of 11
Just tried maintenance reset still got the same issue. Tired both the factory resets. How do I get a new box cause this is driving me insane. Just renewed my contract too.
Message 5 of 11
Sorry, getting my wires crossed, are you able to try a Youview Maintenance Reset  to see if this helps.
If this fails then it would have to be a replacement box.
RyanL
Message 6 of 11
It's now stuck on 1 channel and won't change. Soon as I open tv guide it goes to channel 900 and won't move up or down. Tried the number but won't load channels that way either.
Message 7 of 11
I've turned off optimisation, see if this helps.
RyanL
Message 8 of 11
I've updated my number.
Message 9 of 11
Hi RyanL
Can you add the home phone number rather then the mobile to your profile so I can locate your details.
fre55die
Message 10 of 11
Hi @RyanL
I have escalated this for you.
IMPORTANT !!!!!!
Could you please ensure that your personal information is up to date in your profile.
Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
Thank you
