on 07-02-2019 04:24 PM
Following a recommendation from @Karl-TalkTalk in another of my threads I made an official complaint, on the 22nd Jan via email, regarding the TV Service [Incident: 190122-002352]. The "How do I make a Complaint?" page states: You can email your complaint to concerns@talktalkplc.com and we'll try to reply within 72 hours and the Customer Complaints Code states: We aim to respond to complaints within 10 working days; however, this may not always be possible depending on the nature of your complaint. We’ll let you know if this is the case. However, other than an automated reply saying they would make every effort to reply within 24hrs I have heard absolutely nothing despite sending a number of emails requesting an update as to the progress of my complaint.
So having been given three different time frames for a response, although understandably not necesserarily a resolution, I have not heard anything regarding the complaint or what TaltTalk are doing about it. Could an OCE therefore please chase it up and arrange that I get some feedback.
Answered! Go to Solution.
on 14-02-2019 07:59 AM
As you can see, since the announcement by Youview, nothing has changed, nor will it. You can raise a complaint, you can make a complaint direct to Youview, as it is their software, but the situation will not change. The box will remain branded with TT or BT branding, depending on the service it is connecting from.
on 13-02-2019 11:32 PM
@ferguson my previous ISP was Plusnet, a BT subsidiary.
@Karl-TalkTalk I've tried Youview support and their site just redirected me to TalkTalk for support.
Regarding the announcement you directed me to it seemed to generate a bit of discussion ending with:
on 13-02-2019 01:19 PM
This is also confirmed by the Youview announcement on their forum.
on 13-02-2019 12:57 PM
It is not a TalkTalk "issue," if you were with BT the UI would be similarly changed with their skin. Who was your previous provider?
on 13-02-2019 12:36 PM
@Karl-TalkTalk I haven't tried the Youview forum as I believe it to be a talktalk issue, since my previous broadband provider did not "brand" the box with their TV service. I will however now take a look at the Youview forum to see if there is anything of interest.
on 13-02-2019 10:21 AM
The CEO office should contact you again, but as the branding is updated by the youview software, and ultimately youview, based on the line you are connecting from, there is nothing they can do to remove this, this will always be the case. Have you also tried contacting youview directly to ask the question or posted on the youview forums, as I've found they can be quite helpful.
on 13-02-2019 09:10 AM
@Debbie-TalkTalkHI, the CEO's office contacted me today, but I have to say it was a very disappointing experience. It would appear that they did not bother to read my complaint before contacting me as they assumed I was complaining about the £4 TV Charge. Whereas my complaint actually relates to the Hacking/branding of my 3rd Party Youview box. I now await them reading the complaint and coming back to me with a sensible response.
on 08-02-2019 03:27 PM
@Debbie-TalkTalk Thanks. Hopefully they will perform better than the complaints department.
on 08-02-2019 10:18 AM
Hi Birchcroft
I've now raised this complaint and you will be contacted as soon as possible.
on 08-02-2019 09:27 AM
@Debbie-TalkTalkYes Please
on 08-02-2019 08:20 AM
Hi Birchcroft
Apologies for the delay.
I can raise this complaint over to our CEO's Office and a Complaints Manager would then contact you to discuss this further. Would you like me to arrange this?
