Connection
StevieJ57
Message 3 of 3
Hi, I recently bought a new Samsung tv and connected it to my Huawei Talktalk tv box. Setup was fine but the the tv screen kept going off and on again.  It goes of for a few seconds and comes back on but does this repeatedly.   I disconnected the tv box and just watched regular tv for a few days and all was fine.  Talktalk sent me a new tv box but it has made no difference.   All new cables too.  Any suggestions?
Message 1 of 3
Did you swap the HDMI cable or try a different port on the TV ?
Check the TV menus, does it have any option to change the HDMI settings ?
Message 2 of 3
Assuming you are using an HDMI connection then the only thing remaining to check is the connector on the TV. Have you tried an alternative HDMI input?
