Constant re tuning of talk talk box.
jimbob1986
Whizz Kid
Message 5 of 5
Every couple of weeks I have to re tub my channels as I start to experience pixelation.  The same Ariel in the TV tuner is fine.
James Alderson
4 REPLIES 4
Message 1 of 5
tried this and its fien for a couple of weeks then starts again
James Alderson
Message 2 of 5
Can you try a Youview Maintenance Reset (Option 4: Keep Recordings).
Set the box back up and retune and see if this keeps happening.
Message 3 of 5
the signal strength is minimum of 76 and quality 100 on all multiplexes of freeview.
the TV tuner does not have this issue just the TT box.
once i have returned the pixlating stops.
James Alderson
Message 4 of 5
Are any channels more affected than others ?
What signal strength is showing for the affected channels ?
