Corrupted recordings on TV Plus Box
andyb1231
Message 2 of 2
This is happening more and more frequently and it's now got to the stage where I have to fast forward through each recording to make sure they're not corrupted before I start watching them!
Once the corruption starts it stays corrupted until the end of the recording.
1 REPLY 1
Message 1 of 2
What do you mean by corrupted? Can you be more specific please?
Have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart. Alternatively, you can turn off from the back and power back on.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
Hope it works but if not then please let us know and I’ll flag for further assistance.
Also for a quicker reply can you please ensure you have your personal information up to date in your profile. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
If you are unsure of your phone number, you can find this in My Account or dial 17070 from your land line phone and this will confirm the number for you.
Thank you
