on 20-02-2021 05:09 PM
Coax out connection broken simple fix need new BOX, would be good if we could chat directly with a real person, not getting much joy with this way of communicating 😎
on 24-02-2021 08:20 AM
I'm just sending you a Private Message.
22-02-2021 07:24 PM - edited 22-02-2021 07:26 PM
Strange, i thought this was standard on most TVs these days.
All 3 of mine have 2 coax points, one male one female which are "in and out" and these are next to each other.
what make and model is your TV?
Best wait for and OCE to respond re the box if you cant rewire connections.
on 22-02-2021 07:13 PM
Don't have a aerial out from TV ?
on 20-02-2021 05:28 PM
I'm assuming you have the aerial going into the box and then out to the TV.
Try reversing this so the aerial goes to the TV and then to the box. This should then give both devices the signal they need.
Try a recording on the box with the TV in standby mode to ensure you can record with the tv off.
The reason I'm suggesting this is that TalkTalk are no longer replacing boxes with a new recordable box, but the lite box that does not record.
Hope it works.
