Dn360t
Julshoppie
Message 3 of 3
My youview box updated the apps and now tv app says my youview box is out of date and no longer supported
I have a  Huawei dn360t.01.02.p how do I get a up to date box
Message 1 of 3
Hi Julshoppie
try the resets and let me know how you get on.
Message 2 of 3
3 things to try first are a soft reset by holding the front button for around 10 seconds until the box restarts.
if that doesn't work, then from the settings menu, click on update apps.
if that doesn't work, then try a factory reset of the box which will also reset the apps.
hope this works but if not please let us know.
