Do I have a boost or not??
michaelnuk
Message 10 of 10
Hi all recently subscribed to TalkTalk broadband which went smoothly.
Tried to to add TalkTalk tv and what a disaster!
First tried to add a boost via more tv - no boosts available
After almost an hour on chat to an agent managed to add a boost through them, channels appeared in the EPG and get the below
No problem! I'll press OK = Job done! ..Right??
Noo! I get this
So if I go into my account I can see the boost active but not the box it seems!
If I go into more tv I get this
Yeah sure I am not subscribed to everything! - I'll press Go to my stuff
Oh right nothing there either!
Spent about 4 hours over 4 days and even temprorarly left in frustration!
So so far tried box reboots, router reboots watching the test channel (it works fine!)
last i I heard they had logged a fault with my service and also something about slow broadband - it’s fine! Just the tv that I am having issues with
any ideas? Lost faith with technical support
9 REPLIES 9
Message 1 of 10
You're most welcome. I just know the right people and they're the ones who cracked this for you. Thanks for posting back to let us know it's sorted.
Message 2 of 10
Hi OCE_Ady
Everythings working fine now.
Thanks very much for your help. Not sure what you did but the chat/help thing couldnt figure it out in 4 hours.
Message 3 of 10
Well I'm told this should be fixed now. I've been asked to post asking you to take the following steps:
Please ensure they enter the MORE TV player first. Then come out of the MORE TV player, go to the GUIDE and attempt playback of TV Select boost channels.
Message 4 of 10
It does indeed.  I'll keep you posted when I hear back.
Message 5 of 10
Thanks 🙂
Also if I go into Manage your TV Boosts in my account. No boosts are avalible - Says I have subscribed to them all.
Wouldnt that mean the issue is with TalkTalk and not my box?
Message 6 of 10
I'm not seeing that banner and I've got no stuck orders showing in your account. I'm waiting on a reply from the TV product manager as I suspect this is a communication error with the box. Let me know how you get on with the reset. The MMR often clears issues like this.
Message 7 of 10
Usually that's just what we call a stuck order. It can simply be an order yet to be marked as complete. I'll double check for you.
Message 8 of 10
Nope but a good idea! - I’ll give it a try tonight.
One thing that concerns me though is if I go into my account I get the message Unfortunstley you cannot make changes to your account online right now - it’s been like this for days
makes me think the issue is an account setup issue?
Ady-TalkTalk
Message 9 of 10
Hi michaelnuk, have they had you do the maintenance mode reset?
