Does More TV Still Work?
billbruce
Message 2 of 2
Does the MoreTV section still exist?
I know that the TalkTalk boosts have stopped, but as a legacy customer I still have the entertainment and kids boosts active.
For the last couple of days I noticed a TTG-312 Error when I try to get to MoreTV to watch movies that I have purchased in the past.
We had a power cut and no electricity for about 3 hours last night, so that should have re-set the router. If I try a maintenance re-set on the box will I still be able to access my boost channels?
1 REPLY 1
Message 1 of 2
If the box is reset, you will still be able to access the boost channels.  You may need to follow on screen prompts to set up the channel, but as the boost is active on your account, this would be recognised.
