Error Code TTG-252
Stan012
Message 2 of 2
Hi, I changed from broadband to fibre broadband on 03 May.  Everything has been working perfectly up until tonight when I tried to purchase a film and then play it.  I recieve the error code TTG-252, in fact all the films I have previously purchased are now showing the same error code.  I have read the various posts concerning this code and have so far tried turning the youview box off for 5 minutes and restarting but to no avail.  Have checked system updates etc, they were all updated successfully this morning.  Would anyone be able to offer any other advice?
Many thanks
1 REPLY 1
Message 1 of 2
Hard Reboot box (using button at back of the box)
Perform software update (Menu > Settings > Software Information > Update Software > Press OK on remote)
Load More TV (TalkTalk/More TV button on remote) – More TV will force a subscription check. Select some content from here.
Test the movie playback and see if this works.
