on 21-05-2022 09:01 PM
My settop box is acting up. The tv picture and sound is breaking up and sometimes going off and sometimes does not respond to the remote control. I have tried every I can think of. I put the aerial directly into the TV and it worked ok, put the HDMI lead into a different socket and it was the same, I turned the box off and on again, and reset it to the factory settings but it was still breaking up after a few minutes . I think I need a new box.. 😠
on 25-05-2022 03:50 PM
The old remote will work with the new box.
on 25-05-2022 03:49 PM
I have just received my new set top box. I didn't have a remote control with it. Do I use my old remote control with it?
on 23-05-2022 02:34 PM
A Box is on the way.
on 23-05-2022 02:28 PM
There is just one thing that springs to mind. Have you ensured that the Antenna Out is enabled on the box as after a reset it often defaults to off. Blue Menu/YV button on remote control, > up to settings (cog wheel) > Picture and Sound >Antenna Out.
on 23-05-2022 02:26 PM
Yes please I will give it a go
on 23-05-2022 08:33 AM
Hi rhughes48
I can issue a replacement TV box however TalkTalk no longer provide a recordable box and I can only issue the Lite Box (non recording). Would you like me to send this ?
on 22-05-2022 01:23 PM
They aim to respond within 48 hours (Monday - Friday), but if more urgent you can always try the Service Centre on 0345 172 0088. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk have responded to you, otherwise, this will just put you further down the queue.
