Failed YouView set-top box
Halephyre
Message 3 of 3
Recently my YouView box has been playing up (trouble, or hanging when loading apps or not fully recording programmes). So I tried performing the various factory reset options. Now it begins 'waking up', 'loading' and 'waking up' (again) before eventually ending up in 'Huawei - Maintenance mode' : 'System Start up Error [501]'. And we're back to factory reset.
Time for a replacement box?
Message 1 of 3
I can see a TV Box order was placed by our colleagues on 24th.
Message 2 of 3
yes it seems like it.
i have escalated to the support staffs queue for you.
Please note that if you are eligible for a new box, TalkTalk now only supply non recordable ones.
