Failed to Record since yesterday
KateMOC
Message 7 of 7
Youview DN372T.01.03.P Model has failed to Record all scheduled and impromptu recordings since 10am Sat 25/09/2021. Now also unable to watch previous recordings. Blank screen only but they were fine prior to this fault. Have tried a soft reset. I've tried a Factory Reset keep recording option. I'm not ready to lose my recordings yet so any other suggestions  would be appreciated.
6 REPLIES 6
Message 1 of 7
Thanks for the update 🙂
Message 2 of 7
Pleased to be of help.
KateMOC
Message 3 of 7
I have now done a full factory reset and I'm recording again. Hopefully no more issues as I don't want a box that doesn't record.
Thank you for helping 😀
fre55die
Message 4 of 7
Hi @KateMOC
Just one thought, sometimes the Maintenance reset doesn't "take" first time so I should try it again before proceeding, just in case !!
Message 5 of 7
Hi KateMOC
Follow the advice from fr8ys and do let us know if this helps.
Message 6 of 7
As you have tried the keep recordings option, the only option left is to do the full factory reset.
Yes, you will lose your recordings, but if you are eligible for a new box you will lose them anyway. Please note that if you are eligible for a new box, TalkTalk now only supply non recordable ones., So it's best to try all alternatives if recording is important to you.
Let us know how you get on.
You are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
Thank you
