Failed to record
Shughes1
Message 3 of 3
Huawei youview box fails to record EVERYTHING and has been like this for over a week now! Model: DN372T
I have turned the box off from the mains for more than a minute and the turned back on again and the issue is still there.
Message 1 of 3
Hi Shughes1
Have you tried the reset options as mentioned above ?
Message 2 of 3
Have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart. Alternatively, you can turn off from the back and power back on.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu. You will lose your recordings but you may be asked to do this before the Support Staff look at other alternatives.
You are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
Please note that if you are eligible for a new box, TalkTalk now only supply non recordable ones., So it's best to try all alternatives if recording is important to you.
Hope it works but if not then please let us know and I’ll flag for further assistance.
