Faulty TV box
Adie2020
Message 15 of 15
When I use fast forward at x30 and sometimes at x12 the TV box sticks and I have to turn it off to come out of fast forward
14 REPLIES 14
Message 1 of 15
Glad to hear all is working.
Message 2 of 15
Hi Karl,
Just to let you know that the new box arrived today so I've done a couple of test recordings and everything seems to work just fine.
Fingers crossed it stays that way.
Thanks again for your help.
Adie
Message 3 of 15
No Problem 🙂
Message 4 of 15
Hi Karl,
Many thanks for that.
Adie
Message 5 of 15
Hi Adie
sorry for the delay.  I'll swap out the box and see if this happens on the new box.
Message 6 of 15
Hi Karl,
Is that it then, end of help????
Adie
Message 7 of 15
Hi Karl,
It will occasionally stick at x12 but only if you ff for quite a long time. At x30 it will stay at that speed after about 5s.
Very frustrating!
Adie
Message 8 of 15
If you FF at the setting less than 30 does it not 'stick' is it only at x30 ?
Message 9 of 15
Hi Karl,
I have performed a full factory reset, lost all my recordings etc etc.
Tried a test recording and when I went to fast forward at x30 it got 'stuck' again, really not happy now and ready to throw the box out of the window!
I've also got a very unhappy partner as most of the content recorded was hers!
Adie
Message 10 of 15
The next option then is the full factory reset from the settings menu.
Try this and then make some test recordings.
Message 11 of 15
Hi Karl,
Already tried that as I had read it on another post.
Message 12 of 15
Try a Youview Maintenance Reset (Option 2: Keep Recordings).
Set the box up and retest to see if the behavior improves.
Message 13 of 15
All done thanks
Gliwmaeden2
Message 14 of 15
For TT staff to identify your account,  @Adie2020 , you need to complete your community forum profile details.
Go via your avatar/name; settings; launch profile wizard; make sure you put in your landline phone and and a fallback mobile phone number; save any changes.
It can take several days to get a reply.  Please wait for a response before posting further,  to keep your thread moving forward in the queue.
