Freeview HD Channels Not Working
AKPDM83
Message 14 of 14
I have a problem with my Freeview HD channels (BBC, C5, ITV). It is almost impossible to watch them because the screen either stays completely black or the picture is scrambled or distorted. It worked fine when the antenna cable was connected directly to my TV.
I have already tried to retune my TV box (which resulted in the HD channels disappearing completely). I have also checked the connections and the antenna cable itself. The only thing I noticed is that the signal strength is around 40%.
I hope someone can help here as I would really like to enjoy HD TV alongside my TalkTalk subscription channels!
13 REPLIES 13
Message 1 of 14
Yes please, keep hole of the newer box.
Message 2 of 14
Just tested the new TV box and signal strength is now slightly better at 43% to 50%. Seems to work for the HD channels. I just noticed that the old box seems to pick up a minimally better signal than the new one. Not sure what overall a slightly better signal but I don't think it has anything to do with the TV box itself. Shall I keep the new box and send the old one back?
Thanks!
Message 3 of 14
No Problem 🙂
Message 4 of 14
Cheers, I will keep my eyes peeled.
Message 5 of 14
You may get one.  This should be dispatched via courier and could arrive as early as tomorrow.
Message 6 of 14
Thanks. Will I get an email or so with further information?
Message 7 of 14
Ok, based on your location and transmitter, that does look low.
I want to swap out the box to rule out a fault with the tuner.
I'll get this out to you now.
Message 8 of 14
Just had a look at BBC One. Signal strength is 39-40% and signal quality is 100%.
Message 9 of 14
What is the signal strength for the standard bbc / itv channels (non HD) ?
Message 10 of 14
Done. Over the last two days, HD were again not working for me. Would be great to check what's wrong.
Message 11 of 14
Can you please add your home phone number to your Community Profile so I can locate your details.
If unsure of your number, simply dial 17070 from your land line phone and this will confirm the number for you.
Please reply when this has been updated.
Message 12 of 14
Done that. Reception is now slightly better (Signal strength for BBC One HD is 38%, signal quality is 51%). However, programs still cuts off and is very patchy.
Any other advice?
Thx!
Message 13 of 14
Take the aerial out of the TV box.  Retune the TV box.  No channels will be found, but this will clear the Tuner memory.
Connect the aerial back to the box and retune again and see if the channels return or are better.
Please also check any aerial plugs at the end of the cable are secure and not loose, and check any aerial splitters you may have are corrected correctly.
