Freeview box not working
Butterfly211
Message 6 of 6
Hi, I received a replacement freeview box not long ago but I have problems with this replacement box for the last few weeks, in that it switches itself off after a short period of time and the only way to switch it back on again is via rebooting it using the switch at the back. This sometimes works (but then switches off randomly again), other times it’s just a blank/black screen or bright green screen after the ‘waking up’ message. I’ve tried the reboot (factory reset) / maintenance repair options but this doesn’t seem to fix it ie can only switch on via the reboot switch, randomly turns off.
When is on, some of the apps (channel 4, 5) dont work properly, dont show programmes and remains frozen.
How can I get this fixed?
thank you
5 REPLIES 5
Message 1 of 6
you do not need to do anything 🙂
The Box was dispatched yesterday afternoon and is with a courier and on the way.
Butterfly211
Message 2 of 6
Do I need to do something or will it be sent automatically?
Message 3 of 6
No Problem 🙂
Butterfly211
Message 4 of 6
Thank you
Message 5 of 6
I'll get a replacement TV Box out to you.
