GB News
Evvy1234
Message 3 of 3
Hi there, I'm trying to get the new channel GB News, number 236 but I can't.  I rang TalkTalk and she said to get it through NOW. Is this correct?
fre55die
Message 1 of 3
Hi @Evvy1234
I found that one of my TT box did need a retune to receive it although a second box and my HD TV didn't need it. Just select from the EPG.
Message 2 of 3
Do you see any error messages? Does the channel show as available but you just can't view it? If the channel doesn't show then try retuning your box.
