Getting message 'no signal'. New box sent is the same.
mortontheale
Message 5 of 5
Have spent ages changing cables around and trying all advice to no avail.  Getting very frustrated with it.  New box supplied is exactly the same.  I am quite practical and can usually sort out most problems but this has defeated me.  Would prefer to just cancel subscription.
4 REPLIES 4
Message 1 of 5
When using any device connected via HDMI, be it a youview TV box or DVD player etc, you always have to select HDMI input as the source on the TV. If the aerial is connected to the youview box, you will then also be able to view the freeview channels via the youview box.
mortontheale
Message 2 of 5
Just getting the message 'no signal'.  HDMI connection to TV, Ethernet cable to Router.  Huawei box.  I have since managed to make a connection by selecting HDMI input on TV, but cannot then use TV independantly.
Message 3 of 5
Have you swapped the hdmi cable or tested another hdmi port on the TV. Make sure the TV is also on the correct HDMI channel.
Message 4 of 5
Can you describe your issues please so we can try and help you?
how is your box connected to your TV and Router?
what box do you have?
