on 12-04-2022 06:41 PM
Google tells me that the ITV Hub cannot be accessed using the old TalkTalk box HUAWEI DN 372T from 31.3.22
sure enough I can no longer access the ITV Hub for catch-up tv.
Has anyone else experienced this. I think I need a new box but cannot get hold of anyone for this and no advisor seems to know anything about this.
on 13-04-2022 09:45 AM
Hi Susie,
Can you load the app, is it certain content not working or does the app fail to load. Are there any on screen errors etc.
on 13-04-2022 08:38 AM
The ITV Hub will work with the DN372 Model but is no longer supported on the DN370 Model.
ITV Have updated the App recently. Try a Youview Maintenance Reset to clear and reset the box and update all apps.
on 12-04-2022 07:26 PM
on 12-04-2022 06:48 PM
I am not sure where you looked, but as far as I am aware the 372T box remains supported for the ITV Hub. The 370T model is not.
