on 24-05-2022 09:14 PM
We cannot play recordings with this box even after numerous resets. They will record ok for a few days, then some recordings fail and the rest will not play. We have reset to Factory Settings using the box menu ( hold in + and - buttons on start up) not deleting recordings which worked once, then deleting recordings with Factory reset which worked for a few weeks then it all stopped again. All updates are installed there is over 50% disc space left and it has started again. Any more ideas? this is becoming a bore.
on 25-05-2022 08:39 AM
we can issue a replacement box however it will be a non recording box as we stopped providing these 18 months ago,
on 25-05-2022 06:16 AM
This is the main TalkTalk Freeview box. So if they are not replacing them what do you do. We are only 6 months into a renewed contract. Will have to try and contact them if there are no other fixes. Though livechat is hard to find theses days.
on 24-05-2022 10:31 PM
Devices do fail I'm afraid and judging from what you have told us yours has reached the point of no return. TalkTalk can provide a replacement of sorts if you are a TV subscriber, but they have long since stopped providing recording boxes.
