on 23-03-2021 03:23 PM
When I first had the Youview box I found I had to reset it it about once a fortnight, then it settled down for a while, but for the last few weeks it has needed a retune - and occasionally a reset - everyday.
I'm finding that almost everyday I get severe break up on the picture making it unwatchable or recordable . When I check the figures, the signal strength is down to about 56 percent from about 68%, and the quality down to about 65% from 100%.
Retuning the channels Returns it to its normal signal strength about 68%, and the quality 100%.
on 31-03-2021 06:03 PM
Hi Charlie_bee
Have you tried a maintenance reset? We recommend trying a ‘Factory Reset - Keep Recordings’ first.
on 31-03-2021 05:45 PM
Thanks Debbie
However, I need the recording box to catch all the programs that channels insist on clashing with other channels and the programs occurring at awkward times.
Also, I have well over 100 hours of recorded programs that I still have to watch.
I am hoping that someone can tell me why the box needs retuning every day and what the solution may be.
on 31-03-2021 05:25 PM
Hi Charlie_bee
I can send you a replacement TV box for testing.
Just to advise, TalkTalk no longer provide a recordable box and now only supply the Lite box to all new and existing customers.
on 31-03-2021 02:33 PM
Details added as requested.
on 23-03-2021 04:08 PM
Can you please add your home phone number or Account number to your Community Profile.
We will not attempt to call you, this is so we can locate your account and run tests on your line if you are reporting a fault.
We will then reply via this thread in our Community with any further advice or next steps.
If unsure of your phone number, and if your line is working simply dial 17070 from your land line phone and this will confirm the number for you. Alternatively these details can be found within My Account online or may be on the heading of any paperwork you have received.
Please post back on this thread when this has been done.
