How do I set up my now entertainment and now sports
DavidRowe1
Message 3 of 3
fre55die
Message 1 of 3
Hi @DavidRowe1
You need to visit the NOW home page and set up an account to begin with :
https://www.nowtv.com/gb/sign-in?return=/gb/account/membership.
Message 2 of 3
Now TV is accessed from the set top box via the app however before doing this you must have setup an account with Now TV.
If you have added the Now TV option via TalkTalk, they will send you an email and you can follow the instructions in this.
An account with Now TV is setup via their website at www.nowtv.com
