on 23-03-2021 09:54 PM
Why was I not made aware that the youview box is not WiFi compatible - what century are we living in? Must I have wires all over my living room to allow for streaming BBC iplayer??! I would not have bothered if I had known!
on 24-03-2021 09:48 AM
As Keith advises, there are other options, the majority use powerline adapters to extend the signal to other locations in the home.
on 23-03-2021 10:16 PM
Ethernet will always give a much more reliable connection than WiFi. You do not need to have wires everywhere, you can use powerline adapter kits to extend the connection over the mains electricity.
@Karl-TalkTalk has had success using a TP-Link product to connect via WiFi in this situation, but it will only work if your immediate area is not plagued with WiFi interference. I would always suggest before spending money on this type of solution, to check out the levels of WiFi interference via a WiFi analyser. I can help with this if required.
