Huawei DN370T
DianeB2
Message 7 of 7
Recently box has been slow to start up  and now will not wake at all. Have tried all reset options with no success. So now are paying for talktalk tv which we are unable to access due to dysfunctional box.
6 REPLIES 6
Message 1 of 7
OK, replacement box will be with you soon.
Message 2 of 7
Thanks Karl Had tried software reset, factory reset, internet recovery and exit and restart and each one resulted  in system start up error "your box failed to start up properly". Box had been acting up for quite a few days prior taking a long time to wake up compared to usual.
Message 3 of 7
Hi DianeB2
A replacement TV Box is on the way to you.
This should arrive within the next 48hrs.
Message 4 of 7
Thanks for the reply Karl. Just starting to get familiar with the site. Have added phone number now.
Message 5 of 7
Hi DianeB2
If you can add your home number to your 'Community Profile' I'll pick this up for you.
Message 6 of 7
You are in the staff's queue For a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
If you are unsure of your phone number, you can find this in My Account or dial 17070 from your land line phone and this will confirm the number for you.
You say you have tried all the options. did this include a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If not, try the Factory Reset keep recording option.
If you could confirm that you have updated your info and tried this reset it will speed things up for you.
Thank you
