Huawei tv box not working properly
Rss19
Message 7 of 7
You view talk talk tv huawei box stopped working, followed instructions for factory reset (keep recordings). I can now “see” my recordings in the my tv section, but I cannot play or delete any.  If I try to delete it says “there was a problem deleting this programme try again later”. No program will play either, I just get a blank screen.  The box makes a slight “click” noise about every two minutes.  Please help.
6 REPLIES 6
Message 1 of 7
If the box has failed this cannot be resolved.
I can send a TV box out to you however TalkTalk no longer provide a recording box, only the lite box. Would you like me to send this ?
Rss19
Message 2 of 7
Hi Karl,
Did you get my message? I’ve done the factory reset (delete recordings) and the box still doesn’t work.  Also it makes a “click” noise around every one to two minutes.
Please can you resolve?
Thank you.
Rss19
Message 3 of 7
Hi Karl,
thank you, I have done the full factory reset and it is still not working.  Also the unit is making a “click” noise around every one or two minutes.
thanks for your help.
Message 4 of 7
Unfortunately there is no option to transfer recordings from the box.
Rss19
Message 5 of 7
Thanks Karl, I will try that, is there any way I can “download” the recordings I have before doing this reset?  Thank you.
Message 6 of 7
The only option left to try is the full factory reset from the settings menu.  This will also erase all recordings.
Try this and test a fresh recording and let me know if this still fails.
