Huwawei DN372t not recording
robson737
Message 10 of 10
My DN372t has stopped recording programs (planned and instant) and ALL previously recorded programs will not playback. I have read other similar problems and have been through all of the reset suggestions without any success.
Any ideas please. Thanks Alan
9 REPLIES 9
Message 1 of 10
The box is now on the way.
robson737
Message 2 of 10
Done that (I think)
Message 3 of 10
Add the home phone number to your 'Community Profile' so I can locate your account and I'll orderthe box for you.
robson737
Message 4 of 10
OK yes please send me the lite box.
Things seem to be dropping off TalkTalk tv quite quickly. The first the apps to view and set up recordings then the Sky boosts now the plus box. Shame.
Thanks for your quick responses on this post.
Message 5 of 10
The Teams are looking at a new box for the near future and considering a number of options.
Would you like me to send the lite box ?
robson737
Message 6 of 10
I’m not sure the Lite box will do anymore than the faulty DN372 will it? Having said that, i guess the new Lite box will be new and have the latest software. Do you know why TalkTalk are not supplying the plus boxes anymore?
Thanks for your help Karl
Message 7 of 10
OK, we can replace the box however TalkTalk no longer provide a recording box. Would you like me to send the Lite Box.
robson737
Message 8 of 10
Hi Karl,
I’ve done the full factory reset and the box is just the same. If I try to record, when I go to play the recording it says ‘failed to record’.
Alan
Message 9 of 10
If a full factory reset from the settings menu does not restore functionality then the box may have failed.
Have you tried the full reset ?
