I feel conned
TheDweezil
Message 27 of 27
When I signed up to Talk Talk and had an engineer out to sort things out. He was baffled why the the Youview box was not Wifi. I am disabled. The modem is downstairs. My Youview box is upstairs.  I have been unable to view the box due to no connection. He (the engineer) called Talk Talk and explained that a Ethernet cable would mean much drilling, lifting of carpets and floor boards. Talk Talk told him I would have to pay £85 for a Power Line Adapter/Receiver. I was unaware of this. I can not afford the £85. I do feel conned.
ItsaZappathing
26 REPLIES 26
Message 1 of 27
Yes it is the WiFi extender kit, but it also supports Ethernet connectivity over it. On the Extender unit there is an Ethernet port under one of the antennae.
Message 2 of 27
@KeithFrench  That is the WiFi extender kit. I had one die on me recently and Karl replaced the whole kit having sent a replacement set of PLA's by accident first. This is what the current ones look like although the current model number is DHP-301AV they look identical.
https://www.ebay.co.uk/itm/112376738334
Message 3 of 27
@KeithFrench are they not the wifi extender kit? I used to have one and as far as i remember only the passthrough plug had an ethernet port, so could not double up as powerline adaptors.
I can't see any powerline adaptors in the store which was why I posted a link to the latest ones I am using, that also connect to the previous model I used.
I have one plug connected to the router that powers (connects to) 4 other plugs and devices.
Message 4 of 27
Hi @fre55die
I am looking at the current extender set in front of me now & the network connector does have a mains pass-through socket on it. You can easily see it on the page in the TalkTalk Store:-
TalkTalk | Store ProductDescription
Message 5 of 27
@KeithFrench
The current TT pla's don't have a passthrough apart from on the Wi-Fi extender kit. The current ones are 2 identical units. I think that the last TT provided ones with a passthrough that I had were the White ones with 2 LAN ports, these were about 6-7 years old and for some reason no longer supplied as they are great.
Message 6 of 27
I have just received the TT Transmitter . Free from TT.  Hopefully this will solve all my problems. Thank you to TT and the engineer who have helped me.
ItsaZappathing
Message 7 of 27
Hi @TheDweezil
I totally agree with what @Karl-TalkTalk has just said, with one small exception. The network connector unit (the one that is connected directly to the router) does have a passthrough socket on it. I have no idea what this engineer means by you need a transmitter, as Karl said both units are transmitters & receivers - that is the way any powerline adapter works, not just the TalkTalk ones.
Message 8 of 27
We can only supply the one type of powerline adapter, we do not have the pass through adapters.  Each adapter is both transmitter and a receiver.
Message 9 of 27
@TheDweezil that is what I recommend in my post with a link to those i use but cheaper alternatives are available.
Not sure TalkTalk supply these but hold on for @Karl-TalkTalk to advise.
Message 10 of 27
Engineer called out today. Nice man. He sorted it but said I need a "transmitter" and/or
a power line adaptor / pass through
. This is due to not having many plug sockets.
He is requesting that TT help me out.
ItsaZappathing
Message 11 of 27
Let the engineer look at this and let me know what the engineer advises.
Message 12 of 27
Then it sounds like the units must be faulty, I will ask the OCEs to get involved again.
Message 13 of 27
When the two units are together I still get the same lights?
As for same electrical ring circuit , I wouldn't have a clue. ???
The engineer is coming out tomorrow so hopefully it will get sorted.
Thanks for your reply/help
ItsaZappathing
Message 14 of 27
That proves that the two units are not connecting to each other like you said. This could be down to a problem with one of the two units, or an electrical issue between the two, where they are normally sited.
What happens if you have them both plugged into the same extension lead near the router & the router & network connector connected by the Ethernet cable, does the powerline light come on then?
When you have them in their normal locations, are these on the same electrical ring circuit?
Message 15 of 27
The on light and the cable light
ItsaZappathing
Message 16 of 27
What lights are on each of the two units?
Message 17 of 27
Plugging into a power cable extension reduces the efficiency of the plugs. They work by using the power circuit in the house to pass the signal from one to the other.
Unless you can plug into a wall socket then there is no guarantee they will work. Plugging the one nearest the router into the wall may improve the signal but again no guarantee.
You can purchase your own plugs which are called pass through ones that have a socket built in so you dont actually lose the use of a wall socket. These are what I use, but other makes are available.
https://www.amazon.co.uk/gp/product/B07J652QRY/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
TheDweezil
Message 18 of 27
I know but it still won't work.
I have to use cable extensions . Maybe that's the problem ? No other choice. !!
ItsaZappathing
Message 19 of 27
They should link.
You plug one in by your router and the ethernet cable to the router.
The other goes upstairs and plugs in by the box, with the ethernet cable from the plug to your box.
Message 20 of 27
Received today - two TT adapters. No good. I needed a "Transmitter". I still can't watch my Youview box. I also have no choice but to use an extension lead (other than that it means wires all over the floor, stairs etc). Is there a solution ?
ItsaZappathing
